Tour de Strava 2021: Kevadklassikud
MartV
Postitus Postitas MartV »
Strava segmentidel hakkab tiksuma velotuuri aeg!
Radade valitud segmentidel teeme pühapäeviti kiiruskatsed, mille põhjal selgitame parimad nii etappide kui velotuuri kokkuvõttes.
Üritus Facebookis: https://www.facebook.com/events/1160748651051440/
________________________________________________
❶ RONDE VAN VÄÄNA 4. aprillil
Kogu rada: https://www.strava.com/routes/2809544124138790584
Segmendid:
Tammiaugu – https://www.strava.com/segments/11126055 (boonussekundid: 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Rannamõisa-Liikva (Tabasalu poolt) - https://www.strava.com/segments/11980298
Vääna-Jõesuu laskumine - https://www.strava.com/segments/18550341
Türisalu tõus - https://www.strava.com/segments/1300085 (boonussekundid: 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Looks like Vlaanderen - https://www.strava.com/segments/23995990
Tutermaa-Vanamõisa - https://www.strava.com/segments/23601052
Tiiri tee downhill – https://www.strava.com/segments/23864869 (boonussekundid: 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Alliku > Hüüru kruusal – https://www.strava.com/segments/23621523
_________________________________________________
❷ VIIMSI-ROUBAIX 11.aprillil
Kogu rada: https://www.strava.com/routes/2814466855878011246
Segmendid:
Pikk Jalg https://www.strava.com/segments/20644872 (Boonussekundid 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Vive le Tour de Strava III https://www.strava.com/segments/27912727 (Boonussekundid 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Lükati mägi https://www.strava.com/segments/4964669 (Boonussekundid 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Metsakasti-Tammneeme Tour de Strava https://www.strava.com/segments/27913583
Leppneeme - Püünsi https://www.strava.com/segments/17467090
püünsi-haabneeme https://www.strava.com/segments/7610492
Pargi-Aiandi tee tõus https://www.strava.com/segments/7391762
Vive le Tour de Strava II https://www.strava.com/segments/27912509 (Boonussekundid 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
Randevere Tee Ecolandist-Piritalt https://www.strava.com/segments/7022572
üks ring õige https://www.strava.com/segments/7246203 (120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, 12, ...)
❸ HARKU GOLD RACE 18. aprillil
Kogu rada: https://www.strava.com/routes/27070289
Tilgu tee tõus – https://www.strava.com/segments/4003427
Suurupi väike ring – https://www.strava.com/segments/13337833
Kallaku tee tõus – https://www.strava.com/segments/6248294
Viti to Keila-Joa – https://www.strava.com/segments/18353652
Türisalu tõus – https://www.strava.com/segments/1300085
Vääna-Tutermaa – https://www.strava.com/segments/21649508
Humala tõus – https://www.strava.com/segments/11601474
Tutermaa-Vanamõisa – https://www.strava.com/segments/23601052
Saunapunkti Spurt https://www.strava.com/segments/12156777
(boonussekundid: 180, 120, 90, 70, 60, 50, 45, 40, 35, 30, 25, 20, 18, 17, 16, 15, 14, 13, ...)
❹ LIÈGE-JÕELÄHTME-LIÈGE 25. aprillil
Finaaletapil on kolm uuendust:
1. Arvesse läheb kogu raja (40km) läbimise aeg. Seekord tasub panna kogu aeg!
2. Segmentide aegadel on erinevad kordajad. Aeg hakkab justkui venima ehk segmentide aeg korrutatakse 2ga/3ga/5ga ehk siis tuleb panna veel kõvemini!
3. Velotuuri arvestusse jagame seekord punkte veidi rohkem: 25, 22, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8 ....
Rada: https://www.strava.com/routes/2819194866027863084
Segmendid:
Liège-Jõelähtme-Liège: https://www.strava.com/segments/28140923 X1
Manniva ringrada: https://www.strava.com/segments/28090466 X2 (lõigu aeg sekundites korrutatud kordajaga 2)
Manniva tee tõus: https://www.strava.com/segments/18788088 X5
Jägala - Neeme: https://www.strava.com/segments/24643695 X2
Püha Brigitta allikas ja 3 parmu poe ees: https://www.strava.com/segments/17781737 X3
EGCC Sea Course tõus: https://www.strava.com/segments/12545427 X5
REEGLID
1. Sõidame üksi etteantud rajal segmentide järjekorda arvestades
2. Koos ei sõida ka segmentide vahelistel lõikudel
3. Kui Flyby'st paistab koostööd või muud kahtlast, siis tuleb trahviaega: hinnanguliselt võidetud aeg + veidi ka ekstra
4. Rada tuleb läbida ühe hooga. Osad segmendid on teadlikult paigutatud tihedalt üksteise järgi, nende vahel võib loomulikult kergemalt pedaalida ja nii hinge tõmmata, kuid päris seisma jääda, et puhata, ei tohi
5. Auto pause jms funktsioonid tuleb maha keerata. Muidu on oht, et näiteks liikluse tõttu hoogu langetades läheb sõit pausile ja süsteem ei loe segmenti ära
6. Sõidame just pühapäeviti, edetabel läheb lukku kell 21. Hoolitse, et su sõit oleks sel ajal Stravasse üles laetud ja sealt avalikult leitav
7. Kui etappi sõidad, siis pane vastava ajaga evendi all “going” ja kirjuta Stravas sõidu nimesse “Tour de Strava”
8. Ratas peab olema grupisõidu seades. Ehk palun ei mingeid TT rattaid, lenkse, kettaid ja tilgakiivreid. Jalad sõidavad
9. Sõit toimub avatud liikluses ja omal vastutusel. Täidame liiklusseadust ning hoiame end ja teisi
🏁 Lõpuprotokollid lisame pühapäeva hilisõhtuti siinse event'i alla. Selgitame paremusjärjestuse segmentide, sõitude ja kogu Tour'i kokkuvõttes!
Vive le Tour!
Viimati muutis MartV, 23. 04. 2021. 16:06, muudetud 6 korda kokku.
Re: Tour de Strava 2021: Kevadklassikud
Postitus Postitas DeeJott »
Flyby peale enam loota ei tasu, kuna Strava keeras mingi aeg tagasi flyby kõigil kasutajatel vaikesättena "who can see: no one" asendisse.
https://www.cyclingweekly.com/news/late ... rns-472797
MartV
DeeJott kirjutas: 29. 03. 2021. 18:31 Flyby peale enam loota ei tasu, kuna Strava keeras mingi aeg tagasi flyby kõigil kasutajatel vaikesättena "who can see: no one" asendisse.
Ahha, hea teada. Mis seal ikka, palun siis osalejatel Flyby sisse lülitada siin:
https://www.strava.com/settings/privacy
... aga usun, et keegi ju niikuinii soolotajate petmiseks tuules ei sõidaks, onju!
Osaleja võib ju FlyBy sisse panna aga abimees paneb "No One" ja ongi doping.
MartV kirjutas: 29. 03. 2021. 16:03 Strava segmentidel hakkab tiksuma velotuuri aeg!
(TBA)
Palun tõlget.
Panin selle morse konverterisse ja san vastuseks: ?????????????????????????????????????????
riho kirjutas: 30. 03. 2021. 21:50
MartV kirjutas: 29. 03. 2021. 16:03 (TBA)
Palun tõlget.
TBA = To Be Announced
MartV
1. etapi seisud on selged!
Strava velotuuri ka eelmine aasta külastanud raske jalaga vajutaja Magnus Krusemann võttis pea kõik, mis võtta andis – seitse segmendi võitu ning oli teine vaid Tiiri tee downhillis. Kõva!
Martin Ligema seekord teine ning Karl Hans, kes eelmine aasta osales vaid esimesel etapil on tänavu esimesel etapil kolmas.
Esimene koht naiste arvestuses, päris tugevale sprinterile – Mari-Liis Juul!
Järgmine etapp ja andmine velotuuri üldarvestuses jätkub aga juba sel pühapäeval, 11. aprillil. Kuigi päris Paris-Roubaix lükati edasi oktoobrisse siis meil seda mure pole, Viimsi-Roubaix toimub! Selle etapi võitja, meeste ja naiste kategoorias, saab auhinnaks graveeritud nimega munakivi! Rajal on munakivi sektoreid, pikki tuultele avatud lõike ja Pirita Velotrekk lubas teha ka ringi velodroomil, täpselt nii nagu lõppeb ka päris Paris-Roubaix võidusõit.
Kogu info siin: https://www.facebook.com/events/1160748 ... discussion
MartV
Tour de Strava kevadklassikute teemaline finaal Liège-Jõelähtme-Liège toimub juba sel pühapäeval!
Segmendid:
Tulemused ja muu info: https://www.facebook.com/events/1160748641051441
Mine “Team Vänt sõidud ja võistlused”
