Praktiliselt uus ratas (läbisõit 300 km). Raamisuurus 56 (175-185 pikkusele).
Tehniline info:
- Raam: FC-330 Cross carbon monocoque, 12mm thru-axle with flat-mount disc system, tapered steerer
- Groupset: SRAM Rival 1x11speed, DoubleTap Hydraulic
- Kassett: SRAM PG-1130, 11-32T
- Kett: KMC X11 with MissingLink
- Jooksud: Oval Concepts 324 Disc, Centerlock hubs, 100x12mm & 142x12mm thru Axles, 700c 24/28H rims
- Rehvid:Vittoria Terreno Mix, 700x33, 120 tpi, folding, TNT tubeless ready
- Ketaspidurid: SRAM Rival Hydraulic disc for road, 160mm rotors
- Sadulapost: Oval Concepts 310 Ergo, 6061 alloy, 31.8mm clamp, 133mm drop, 4° sweep
- Sadul: Oval Concepts X38 with pressure relief zone, cromo rails
- Sadulapost:Oval Concepts 905, carbon & alloy, 27.2mm diameter
- Kaal: ca. 8.93 kg
Info:
https://www.tradeinn.com/bikeinn/en/fuj ... 37624752/p
Pildid:
https://photos.app.goo.gl/FMrBE8iwMbig9ZgL8
Hinnasoov: 1200€
Tel.56697137
M: Cyclo/Gravel Fuji Altamira cx 1.3 (müüdud)
